Saving multiple color correction effects to one preset.
Christopher Arata
on Oct 6, 2015 at 8:09:41 pm
Can you save a Lumetri effect & three-way color corrector as one preset? I have been trying to save a Lumetri color effect along with adjustments I made with the three-way color corrector into one but it doesn't seem to want to work. Any ideas?
Ann Bens
Re: Saving multiple color correction effects to one preset.
on Oct 6, 2015 at 10:24:06 pm
Select both effects in the Effect Controls by Ctrl click both effects: right click: save preset.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Christopher Arata
on Oct 6, 2015 at 10:35:31 pm
That is what I have been trying to do. It will only save the top effect for some reason, in this case that is the three-way color corrector. I have tried switching the order Lumetri Color first then the Three-Way but that didn't work. I have been able to save them seperatly but had to remove the Lumetri effect before the Three-way would save properly & vice versa.
Duke Sweden
on Oct 7, 2015 at 11:46:55 am
Are you saying you can select both to add to your preset but only one shows up? I've had no trouble adding multiple color correction plugins to my presets, and I'm a buffoon.
Christopher Arata
on Oct 7, 2015 at 3:07:22 pm
Correct. I feel like it has something to do with the Lumetri effect.
Duke Sweden
on Oct 7, 2015 at 4:53:54 pm
You know what? I just checked all my presets and you're right. Only the lumetri adjustments are there. Told ya I was a buffoon. I guess that doesn't really solve your dilemma, though.
Christopher Arata
on Oct 7, 2015 at 5:00:57 pm
That's a bummer. Yeah it's pretty frustrating, I don't really understand why it won't save everything.
Robert d'Alexis
on Oct 9, 2015 at 1:21:17 am
Have you tried saving the preset with both effects applied using the drop down menu of the Effect Controls panel as opposed to going the Ctrl-click > Right-click > save preset route as described above?
Give it a shot and see if it works for you because it does for me.
Christopher Arata
on Oct 12, 2015 at 8:46:17 pm
I tried everything that everyone has mentioned before posting the question & then tried again, & again, with no luck. I appreciate everyones feedback. It just seems to not want to work for me. Last bit of info that I don't think should make a difference but Im Mac based & using the latest version of Premiere Pro CC.
Andrew Penchuk
on Aug 10, 2017 at 3:35:47 pm
I know this is a 2 year old post, but I stumbled upon the same issue.
However, I found a solution!
After highlighting all of the effects, make sure you right click on the bottom (last) effect, not the top one. Then all the effects will be saved!
Matt Bacon
on Oct 12, 2018 at 9:49:52 pm
Andrew's suggestion did not fix this bug/problem for me.
It's a very sneaky bug, because sometimes (ONLY SOMETIMES) the preset works correctly and applies the actual amount of Lumetri effects you attempted to save as a preset. I believe the preset works correctly when you apply it for the first time after a fresh launch of PP... but I'm not confident of this nor does it really help.
I LOVE stacking Lumetri effects: one for base correction, one for skin tone, one for applying a look (although the look step is often best achieved with an adjustment layer). Regardless, this bug sucks.
My solution is to save each stacked Lumetri effect as its own preset and name them in a sequential way: INTV WS 1, INTV WS 2, etc. Make sure you number your presets in a way that reminds you of the stack order (order matters), in my case the highest number is on the bottom of the stack in the Effect Controls panel.
Does anyone know of another solution or if this bug was ever reported? I'm on CC 12.1.1 (Build 10) running Windows 10.
Ann Bens
on Oct 7, 2015 at 5:06:35 pm
It works for me.
Try hovering over the lumetri effect while saving to a preset
Duke Sweden
on Oct 8, 2015 at 11:46:27 pm
I'm positive that when I added one of my presets to a clip all of the components were included. The preset would always show up in the effects window fully expanded, showing all the components included in the preset.
I think this problem popped up with the latest update. I almost guarantee that's the case. Hovering over the lumetri effects is clever but I think this would be fixed in the next update.
Ann Bens
on Oct 12, 2015 at 8:57:53 pm
If you have issues with the presets file a bugreport.
If Adobe can reproduce (which I cannot) it might get fixed.
http://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
