Merging clip with audio makes it mono
Ben Cooper
on Oct 6, 2015 at 3:51:20 pm
Hi! I have a problem when merging a video I took with my camera and an audio file I recorded separately. The audio file is stereo and it is essential that it will stay that way but when I merge the clip with the audio it turns it into a two channel mono. It mixes both the channels then creates two mono channels. How do I stop it from doing that?
Can't it just merge the video with the audio as it is?
Jon Doughtie
Re: Merging clip with audio makes it mono
on Oct 6, 2015 at 7:07:31 pm
When you indicated you "merge" them, do you mean you are placing them together on the timeline?
If so. . .
Before you place the audio in the timeline, right-click it in the bin. Select "Modify" and set up the audio to appear in the timeline the way you want it to be.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2014 (as of 7/2015)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
Ben Cooper
on Oct 6, 2015 at 7:45:18 pm
No, I choose them both and select "merge clips" to replace the original audio.
I also found out that if I pan the audio mixer ch.1 to far left and ch.2 to far right that seems to fix it. But why does it do that?
