Reducing Flicker from lighting
Amber Sanders
on Oct 3, 2015 at 1:50:51 pm
Hi there,
I have some footage that was filmed 25p 1/50 shutter on a canon 5d mkiii in a 50z area. I think the lighting was slightly out of the 50hz range so i have lighting flicker on the footage.
I have read about using Denoiser to reduce it, but am having no success, can any one help me with the settings?
I have Red Ginat Denoiser II installed
Thank you!
Massimo Alberto Croce
Re: Reducing Flicker from lighting
on Oct 3, 2015 at 2:13:15 pm
Put another copy of the clip in superimpose at 50% slip it by one frame.
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
Amber Sanders
on Oct 3, 2015 at 2:16:29 pm
Hi Massimo, thanks for your message
sorry just so i understand clearly
Do you mean so that the superimosed clip is one frame ahead/behind?
Amber Sanders
on Oct 3, 2015 at 2:21:28 pm
I got that to work, but it produces a lot of motion blur?
on Oct 3, 2015 at 7:00:20 pm
Yes. This method introduce a little bit of motion blur, but you I think this is better than flickering.
Chris Wright
on Oct 3, 2015 at 3:38:57 pm
does the flicker affect the whole image?
i made a deflicker a while back.
after effects cs3
https://f1.creativecow.net/6154/auto-white-balance-cs3-and-up
if you enable the text layer and scroll Gamma Clamp at gamma*10 so that the text box reads 25, it will
fix timelapse and old movie's flicker.
these work in premiere:
http://www.granitebaysoftware.com/products/productgbd.aspx
http://www.digitalanarchy.com/Flicker/main.html
http://www.revisionfx.com/products/deflicker/
Amber Sanders
on Oct 4, 2015 at 7:21:12 am
It does, annoyingly i would not be able to mask it.
I have just tried FlickerFree by Digital Anarchy and i really seems to have don't the job, although just using the trial at the moment, annoyingly buying it takes a chunk out of my rate for the job, but it might be the best option.
Thanks Chris i will try those now
Amber
Ann Bens
on Oct 4, 2015 at 10:06:41 am
I recently had the same issue: different light frequency.
Used DE:Flicker from DE:Vision.
Not a cheap solution but it fixed my problem.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Micah Eavenson
on Feb 8, 2017 at 9:55:14 pm
This is an old thread. However, perhaps this screencast could help someone in the future.
http://www.videoprowess.com
Live, Love, Shoot
Kannan Raghavan
on Feb 10, 2017 at 7:09:12 am
I usually use FCP X or PrPro but had to use Avid a few months back at a client's place. There is a flicker removal filter in MC that works really well. AM not sure if it was a third party plugin or a built in filter though.
Kannan Raghavan
The Big Toad Films Pte. Ltd.
