Premiere Live Text Template Issues. Unable to change text in Premiere from After Effects. Any assistance is appreciated!
Jake Frader
on Sep 29, 2015 at 3:08:42 pm
I am currently working for a client incorporating After Effects graphics into Adobe Premiere and am having issues using the Live Text Template in Premiere and changing the text of specific After Affects graphics in Premiere. This has never happened to me before and I am quite perplexed. I have the most recent update of the Adobe Cloud. Every time I import the after effects graphics into Premiere and go to Effect Controls to change the text, there is no option for me to change the text.
Has anyone else had this issue and have thoughts as to why I am unable to adjust the text? The motion graphics person says that it is working for him and his colleague. He is working in cc2014 and I am working with cc2015. Could this be the issue? Any help would be greatly appreciated as this is a time sensitive project.
Thank you.
Paul Neumann
Re: Premiere Live Text Template Issues. Unable to change text in Premiere from After Effects. Any assistance is appreciated!
on Sep 30, 2015 at 2:17:15 pm
Make sure you have the text enabled to be edited in the AE comp. Also, make sure you are using "Open In Source Monitor" and not "Import".
Jake Frader
on Oct 1, 2015 at 4:35:55 pm
Thank you for your response. Unfortunately, I have looked in to both those issues. Is there any potential plug in, etc that I could be missing? I have the latest version of the cloud so I am having trouble understanding what I am missing. The graphic designer told me that his colleague is able to work with the files.
Alex Udell
on Oct 2, 2015 at 2:30:39 pm
If you take his project....
open it in your copy of after effects and SAVE AS....
then try to move forward with the PPro workflow linking to your saved version....
does that work?
the version mismatch between the AE comps might make all the difference....as they may be looking at different dynamic link "server" versions...or something like that....
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
