working with mxf files in 2015 CC
Welland Man
on Sep 28, 2015 at 11:14:52 am
when i import a mxf file in itshoes 5 tracks so takes up all the room so when i get round to doing 5 camamera angles in multi cam going to be a nightmare
can i lick somewhere where only shows 2 tracks video and audio
Andy Edwards
Re: working with mxf files in 2015 CC
on Sep 28, 2015 at 2:57:54 pm
Just modify your MXF clips before you create your multi-cam sequence. You can "lick" them before creating the sequence :-)
If you don't actually need all the channels of audio from each camera, just right click on them in the project bin and choose Modify / Audio Channels. Change from 5 Audio tracks to 2 and choose the format (mono / Stereo) you want. Once you have modified all cameras, then select them all and create your multi cam sequence.
Andy Edwards
