Final Cut rewrapped DVCPROHD MOV won't import into CS3
Nathan Quattrini
on Jun 16, 2009 at 4:08:58 am
My friend color corrected footage that I exported as P2 (it was P2 from the beginning) from CS3. He worked on it in Final Cut and gave me back an Mov file which is rewrapped as DVCPRO HD. I tried everything, including making a DVCPRO HD projct in Premiere and importing, and it still says 'Codec is missing or unsupported'. How can I open this file? I'm going nuts trying to figure it out.
Jon Barrie
Re: Final Cut rewrapped DVCPROHD MOV won't import into CS3
on Jun 16, 2009 at 5:12:22 am
Sorry to be the bearer of bad news, but unless you have an Apple system with FCP or FCS on it you can't read the file format. The codecs are proprietary for FCP environments and that means no PC support either.
You need the file converted or re exported to a non-FCP environment, namely ProRes (can get downloads for the playback of it, PC too, you will get a gamma shift in the export) or Animation. File sizes will be much larger in Animation, but you won't lose any quality and you can use it on any system.
- JB
Jon Barrie
aJBprods
http://www.jonbarrie.net
Larry Applegate
on Jul 11, 2009 at 11:11:34 pm
I have Final Cut Sudio 2.0 on the same machine as Adobe Production Bundle CS4. But in Premiere I still can't find the right codec. How can I install it into Premiere?
Regards,
Larry
Eric Jurgenson
on Jun 16, 2009 at 1:26:02 pm
Check out the raylight decoder:
http://www.dvfilm.com/raylight/decoder/index.htm
Nathan Quattrini
on Jun 16, 2009 at 9:47:08 pm
forgot to mention I`m on a Mac :(
Greg Booth
on Jun 17, 2009 at 1:30:08 am
You can try out a demo of our Calibrated{Q} DVCProHD Decode for OSX here:
http://www.calibratedsoftware.com/QDVCProHD.asp
Cheers,
Greg
Calibrated Software
