iso-639
Mauricio Mendes
iso-639
on Jun 3, 2020 at 2:01:06 pm
Hi:
I need to export a multichannel file where each audio track language should be identified by the ISO-639 standards.
I exported a multichannel Quicktime ProRes 442, but all its tracks are set to English (en). Where can I change that so I can correctly identify each audio channel?
Thanks in advance.Mauricio
Andy Ford
Re: iso-639
on Jun 8, 2020 at 11:01:45 pm
Assuming all your audio channels are labeled and assigned in Premiere, when you export from Premiere and Media Encoder comes up, select the Quicktime format and under the Audio options, go down to Audio Channel Configuration. Click on the plus sign to add more channels to export out individual splits for your languages.
Video Producer / Digital Marketer / Gear Reviewer / Author
----- http://www.AndyFordVideo.com -----
Mauricio Mendes
Re: iso-639
on Jun 9, 2020 at 12:29:20 pm
Hi Andy:
This is the procedure to export multichannel Quicktime, and even labeling the audio channels correctly on the timeline, the exported file still mislabeled. Testing on MediaInfo, all channels are labeled as "English".
I'm trying to send a video to the new Youtube Feature that will allow viewers to choose the language of their films, and the audio channels must be labeled according to the ISO-639 format. How can I make it happen?
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 2005.03 (qt )
File size : 1.64 GiB
Duration : 7 min 2 s
Overall bit rate : 33.4 Mb/s
Encoded date : UTC 2020-06-13 12:14:27
Tagged date : UTC 2020-06-09 12:17:41
Writing library : Apple QuickTime
TIM : 00:00:00:00
TSC : 2997
TSZ : 100
Video
Format : DV
Codec ID : dvc
Bit rate mode : Constant
Bit rate : 24.4 Mb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Original display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 (29970/1000) FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:1:1
Bit depth : 8 bits
Scan type : Progressive
Original scan type : Interlaced
Original scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.357
Stream size : 1.20 GiB (73%)
Language : English
Tagged date : UTC 2020-06-13 12:14:27
Audio #1
Format : PCM
Format settings : Little / Signed
Codec ID : sowt
Bit rate : 1 536 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Stream size : 77.4 MiB (5%)
Language : English
Audio #2
Format : PCM
Codec ID : sowt
Bit depth : 16 bits
Language : English
Audio #3
Format : PCM
Codec ID : sowt
Bit depth : 16 bits
Language : English
Other
Type : Time code
Format : QuickTime TC
Time code of first frame : 00:00:00:00
Time code, striped : Yes
Language : English
Mauricio Mendes
Re: iso-639
on Jun 9, 2020 at 12:47:55 pm
I renamed the channels on Premiere, according to the audio language.
Should I do something else? Is there something I'm missing?
Thanks in Advance
Mauricio
Andy Ford
Re: iso-639
on Jun 9, 2020 at 4:48:05 pm
See if this tutorial helps you ensure you did all the steps:
https://www.premiumbeat.com/blog/export-multiple-audio-tracks-premiere-pro/
