Identifying and replicating effects in clip
André Brasil
on Apr 23, 2020 at 3:29:05 pm
Hello,
I'm 100% new to Premiere. Nonetheless I'm used to pick things up from the ground and build my knowledge. Also, I'm pretty determined to get this done!
This is the clip:
https://www.dropbox.com/s/k05pdjjfxfc7quj/videoHQ.mp4?dl=0
I've watched it several times and have identified what I believe are the following effects:
  • Blurred light leak effect on the background with animated text on top
  • Light leak effects blended into all the slides
  • Particle effects blended into all the slides
  • Zoom out effect following a logarithmic progression (faster in the beginning and slower mid way)
  • Horizontal and vertical transitions
  • Blur bar right after the transition, that "docks" on top or bottom, also following a logarithmic speed progression.
  • Background music
Do these look accurate? Any other effects that I might have missed?
The light leak and particle effects look simple enough to implement but the transition effects with nice zoom out effect and moving blur bar look harder from my standpoint.
Any help would be amazing!
PS: I'm using Premiere Pro CC version 13 (2019) for Windows 10
greg janza
Re: Identifying and replicating effects in clip
on Apr 23, 2020 at 10:12:53 pm
That video was definitely made from a purchased template. There are a number of online marketplace sites that sell video templates for AE as well as Premiere. The easiest way to learn the effects used is to simply purchase one of these templates. This looks to be an AE template.
https://www.linkedin.com/in/tmprods
tallmanproductions.net
