SRT file not complete in Premiere
Angharad Overton
on Oct 7, 2019 at 12:59:25 pm
Hello CC people,
A film was sent to an external company for subtitling. They have sent back .SRT files.
When I opened it in PP it came out very short, with only 4 of 70 captions showing.
I tried converting it to a .scc which then reveals the full file info, but apostrophes get converted to special characters. I then tried a Unicode converter which resulted in only 4/70 captions showing (at least it had working apostrophes!)
I contacted the company and their advice seems to be to reimport the file, but the exact same thing happens each time. Where am I going wrong?
Thank you for your help!
Eric Santiago
Re: SRT file not complete in Premiere
on Oct 7, 2019 at 1:43:51 pm
Do you have another NLE to test this on?
Angharad Overton
on Oct 7, 2019 at 2:07:23 pm
Hey Eric,
Thank you for replying. I have found a fix.
There is a reason it cut off at 4/70 specifically.
To fix this issue you need to open the .srt file in a text editor. Between each line of code there should be one line break only (see below).
1
00:00:08,440 --> 00:00:11,000
And then we went through
a funny little door somewhere
2
00:00:11,080 --> 00:00:14,040
which nobody seemed
to know about at the time.
There were two line breaks between several lines of text, which seemed to make PP freak out! (example below...)
1
2
which nobody seemed
Simply ensure there is one line break between each caption and it will fix the problem. Then reimport and enjoy!
Best wishes,
A
Tod Hopkins
on Oct 9, 2019 at 12:19:06 pm
Note that two blank lines will stop the import even if one of the blank lines is logically part of two line captions. That is, if the second line in a two line caption is blank, acting as a visual placeholder for line 2.
1
And we went through the door
2
which nobody seemed
Some caption tools will do this routinely.
Cheers,
tod
Tod Hopkins
Hillmann & Carr Inc.
Washington, DC
