adobe premiere export multi format
nick hartcher
on Oct 4, 2019 at 1:57:23 pm
hey team,
I am currently have multiple projects and sequences in premiere that I need to export so that I can send to various people so that they can edit in thier own programs such as Final Cut Pro
what is the best format and settings to do this without sending the original RAW video files to them?
thanks in advance Nick
Blaise Douros
Re: adobe premiere export multi format
on Oct 4, 2019 at 9:44:02 pm
If they don't have the media, they can't edit it. Are you suggesting that you'd like to transcode all the media to a smaller-file-size codec, and send it to them along with the sequence? If so, Adobe Media Encoder will batch export them. You can also render proxies via Premiere's proxy workflow.
nick hartcher
on Oct 8, 2019 at 10:53:10 am
ok great thanks for the reply. yes which setting should I use to output at maximum quality?
Blaise Douros
on Oct 8, 2019 at 4:12:34 pm
Maximum quality and file portability are mutually exclusive. Use ProRes or DNxHD at the native resolution for a visually lossless transfer, but don't expect it to be small.
greg janza
on Oct 4, 2019 at 9:49:31 pm
This is potentially asking for a lot of headache, Is it absolutely necessary for the projects to be worked on outside of Premiere?
https://www.linkedin.com/in/tmprods
tallmanproductions.net
