Can't export higher than 4K
Sa Dilshan
on Sep 10, 2019 at 6:06:26 am
Hi, I can't export anything higher than 4096x2048.
Shane Ross
Re: Can't export higher than 4K
on Sep 10, 2019 at 6:31:53 am
What are your project settings? 4K? Or higher?
Shane
Little Frog Post
Sa Dilshan
on Sep 10, 2019 at 6:46:58 am
5760x2880. Can't go higher even in manual export settings.
Tero Ahlfors
on Sep 10, 2019 at 6:42:08 am
Your H264 level is probably too low. https://en.wikipedia.org/wiki/Advanced_Video_Coding#Levels
Sa Dilshan
on Sep 10, 2019 at 6:50:17 am
Thank You. Are there any solution? I tried RAW files from different cameras. But got the same result.
Tero Ahlfors
on Sep 10, 2019 at 7:42:38 am
[Sa Dilshan] "Are there any solution?"
Use a high enough H264 level that can output the resolution you need. Or export to a format that doesn't have those kind of restrictions.
Antoine Dorni
on Sep 22, 2019 at 10:17:21 am
Hi Sa,
If you're still looking for a solution, AfterCodecs doesn't have this resolution limitation https://autokroma.com/AfterCodecs/
AfterCodecs and BRAW Studio plugins for Adobe CC https://autokroma.com/
