A few new MacPro fall 2019 questions
steve Zavo
on Sep 9, 2019 at 6:56:24 pm
Can anyone answer these please regarding MacPro fall 2019:
Maybe I want to stick with my beautiful NEC monitors.
Will those connectors remain the same? (DVI-D)
Will there be a way to connect my eSATA drives?
Can anyone suggest a most appropriate configuration
from this page, eg processor, memory:
https://www.apple.com/mac-pro/specs/
for Photoshop files, some times up to 1.5 GB;
video editing: generally 60 4K 2 minute clips at a time input;
2 minute finished videos 4K output.
Steve Z
Shane Ross
Re: A few new MacPro fall 2019 questions
on Sep 10, 2019 at 12:50:37 am
[steve Zavo] "Maybe I want to stick with my beautiful NEC monitors.
Will those connectors remain the same? (DVI-D)"
You'll need thunderbolt adapters.
[steve Zavo] "Will there be a way to connect my eSATA drives?"
You'll need an adapter, most likely USB-C will be the option.
[steve Zavo] "Can anyone suggest a most appropriate configuration
from this page, eg processor, memory:"
You can afford more than the base model? I can't even afford that. The base would be fine for many many things, even Resolve and PPro. Get what you can afford.
[steve Zavo] "video editing: generally 60 4K 2 minute clips at a time input;"
You'll need drives with connectors far faster than eSATA. Thunderbolt 3 RAIDs for 4K 60p. Fast drives is what helps with large data rate video filse.
[steve Zavo] "for Photoshop files, some times up to 1.5 GB;"
64GB RAM
[steve Zavo] "2 minute finished videos 4K output."
This can be done quickly with an iMac 5K, nothing special about that. 2 min? Lickity split...base MacPro will do that.
Shane
Little Frog Post
Todd Perchert
on Sep 10, 2019 at 2:00:51 pm
I would just go with the 1.5TB RAM. Excess is what's needed here. LOL!
I just wonder what they charge for 1.5TB of RAM loaded into it...
