Can't resize UI window
Robert Withers
on Sep 1, 2019 at 8:40:59 pm
Hello, I'm working with Pr 2019 on an underpowered Macbook Air (away from home) and the project windows come up too big, particularly the height. I can't resize the window to fit on my screen cause I can't get the cursor onto the bottom edge.
Not the green dot issue -- that still leaves too much of the UI off and below the screen.
This might have happened when I plugged in a TV as monitor -- but that's disconnected and I've restarted. The Macbook Air is set at maximum and appropriate resolution for the display.
The Welcome screen is fine, but when I open any old or new project window it falls off the bottom of the screen.
What's the magic needed here?
Robert
Robert Withers
Independent/personal/avant-garde cinema, New York City
Robert Withers
Re: Can't resize UI window
on Sep 1, 2019 at 9:59:32 pm
SOLVED! By resetting preferences and fiddling a bit more.
Robert Withers
Todd Perchert
on Sep 4, 2019 at 6:32:49 pm
Yep. Trash the prefs. Also, I would save a custom layout. I have one for dual monitor and single monitor. When I need to, I revert to it.
TC
Robert Withers
on Sep 4, 2019 at 7:55:34 pm
Thanks, Todd.
How do you trash the prefs in Resolve?
R
Robert Withers
