PP 2019 - exports not embedding time code
Ivan Nabereznyj
on Aug 26, 2019 at 8:26:21 pm
Using the most up-to-date PP and brought in a QT that has 0-hour TC start but has BITC at 00:59:40:00. Want to export new video with embedded TC to match BITC. Have change all settings to start at 00:59:40:00 but cannot get an export with proper time start.
Attached is a series of screen grabs with the various time code set 00:59:40:00 and a sample output:
13661_pp2019embednotworking.png.zip
Thanks in advance,
Ivan (john)
Tero Ahlfors
Re: PP 2019 - exports not embedding time code
on Aug 27, 2019 at 7:23:12 am
QT Pro has been dead for a while and I'm not sure it reads timecode from .mp4 files. If you bring the file back to Premiere does it have the timecode?
Ivan Nabereznyj
on Aug 27, 2019 at 8:13:44 am
Thanks, Tero. No, the time code is still 0-hour when I bring back into PP.
QT Pro may be dead from a development standpoint but it still is useful in telling me what audio, video and time code streams I'm dealing with. And is good for quick and dirty cutdowns.
I use several different pieces of software and if QT Pro tells me there's no embedded TC then none of them see embedded TC.
Alternatively is there a way to export as and .mov file? Maybe that would embed the TC properly.
Thank you for your guidance.
Ivan (John)
Doug Metz
on Aug 27, 2019 at 8:50:40 pm
EDIT - misread OP. Whoops!
Doug Metz
on Aug 27, 2019 at 9:27:15 pm
{ Ivan Nabereznyj } - Alternatively is there a way to export as and .mov file? Maybe that would embed the TC properly.
I just had a go at this - with your start time edited to your beginning BITC, exporting as .mov does the trick!
Doug Metz
Dalton Agency
Ivan Nabereznyj
on Aug 27, 2019 at 10:47:16 pm
Yes, Doug, that does the trick. I kept exporting same as source and that was the downfall.
Thank for your help!
Ivan
