Proxies squeezed although right resolution
Tomas Medek
on Aug 12, 2019 at 10:05:12 am
Hi. It drives me crazy ☺ Original footage is 2160x3840 (9:16). Proxies are 720x1280 (9:16). But it still looks like this... Can anyone help me how to set things right? Thanks to everyone!
David Roth Weiss
Re: Proxies squeezed although right resolution
on Aug 12, 2019 at 3:52:37 pm
You chose an anamorphic format that should have a check box allowing you to toggle anamorphic on or off, you want it off.
However, you seem to be looking at proxies in the wrong way... You’d probably be far better off using a codec with the same pixel dimensions as your camera original, simply choosing a less demanding resolution and codec. That way, all of your graphics and text will translate appropriately when and if you ever wish to reconfirm using your camera original.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro Legacy forum.
Tomas Medek
on Aug 17, 2019 at 1:34:27 pm
Thank you for your reply but I didn´t choose anamorphic format (consciously or by mistake).
Also my camera aspect ratio is 9:16 as well asi proxy. My camera pixel aspect ratio is "square pixels 1.0" as well as proxy.
I´m using proxies for years and sometimes this happens with no obvious reason.
