Mogrt error and revision
Kathi Beasley
on Jun 2, 2019 at 6:36:37 pm
I was recently involved in a project using mogrts. At the end of the day, it was discovered that a typo existed in a lower third that had been edited throughout a 24 minute program. Is there a way to globally change the mogrt quickly without having to highlight each section on the timeline and make each change separately? There was quite a bit of panic to make the deadline using the second more lengthy method.
John Heiser
Re: Mogrt error and revision
on Jun 14, 2019 at 3:55:20 pm
As you've probably noticed from the lack of responses, the answer is "no." There's no global method of changing elements in graphics clips. It would be great, though, especially if it's a MOGRT created in AE, to be able to correct it in AE, overwrite it in Essential Graphics, and have that change update dynamically.
John Heiser
Senior Editor
o2 ideas - Birmingham, AL
iMac Retina 5k, 27-inch, 2017
4.2 GHz i7, 32GB RAM, Radeon Pro 580 8GB
G-Speed Studio TB-2 12TB RAID-5
Kathi Beasley
on Jun 14, 2019 at 7:16:30 pm
Thanks John.
Adobe should definitely put that on its list of needed updates.
