Titles that can't be seen
Eric Merklein
on May 19, 2019 at 5:43:35 pm
I'm in a 1080 project using material that was shot 4K.
PROBLEM: I created two lower thirds for on camera ID's. When I put the title over video in ch. 1, I cannot see the title. If I double click to get into the title tool, I can see it.
Rendering doesn't help and i cant see the lower thirds even if I insert on ch 1.
I hope someone has a fix for me.
Many thanks.
Eric
Paul Neumann
Re: Titles that can't be seen
on May 20, 2019 at 3:29:59 am
Right click on the title and set to frame size.
Eric Merklein
on May 20, 2019 at 10:37:12 am
Thank you Paul. In all this time I haven't seen this re-size option. It worked.
Eric :)
Paul Neumann
on May 21, 2019 at 1:19:05 pm
You've probably got a 4k title on a HD timeline. I bet if you check the scale on the title it will be 50%.
Eric Merklein
on May 21, 2019 at 1:25:07 pm
You are absolutely correct Paul. Thank you for bailing me out
e
