Glitchy clip in PPro sequence
Neil Orman
on Apr 30, 2019 at 3:13:47 pm
I inserted a cell phone clip into a PPro sequence, and it's not playing smoothly in the video, although it plays fine outside my sequence. Any thoughts on possible solutions would be greatly appreciated. You can see the glitchy clip at the :37 mark of the video, which you can view at https://vimeo.com/333025537, with the password 'startup.'
Thanks, Neil
Neil Orman
Re: Glitchy clip in PPro sequence
on Apr 30, 2019 at 4:37:13 pm
By the way I discovered the clip in question (the one of the girl speaking) has a frame rate of 17.98, and it's in a 29.97 sequence. Could that be what's causing the interruption and flickering green color around the :37 mark? I actually tried creating a 17.98 frame rate sequence though, and the problem persisted. Any thoughts much appreciated!
Neil Orman
on Apr 30, 2019 at 5:19:33 pm
Never mind on this one, I came up with another solution.
Thanks, Neil
Jeff Pulera
on Apr 30, 2019 at 5:30:48 pm
Hi Neil,
Cell phone video is often Variable Frame Rate. Many users resolve this issue by converting the clip using the free Handbrake application. Make sure the Output is set to Constant Frame Rate of 29.97 and edit the resulting .mp4 in Premiere then.
Jeff
Jeff Pulera
Safe Harbor Computers
