Remove all cross dissolves
Joseph Freeman III
on Apr 16, 2019 at 2:05:23 am
Is there a way to globally remove all instances of an effect, such as cross dissolve? This effect is not included in remove attributes.
Thanks in advance.
Joseph
Kevin Anton
Re: Remove all cross dissolves
on Apr 16, 2019 at 7:49:03 pm
Here is an odd workaround to remove a lot of cross dissolves at once:
Forum topic on this:
https://forums.adobe.com/thread/2416830
I know of no other ways to do this other than manually, but maybe someone else can chime in.
Joseph Freeman III
on Apr 16, 2019 at 8:12:52 pm
Kevin,
Thanks for your clever solution and links...This approach will eliminate much of the work.
A welcome future feature in Premiere Pro, hopefully.
Joseph
Joseph Freeman III
on Apr 16, 2019 at 8:45:01 pm
I Spoke too soon.
When selecting all clips, in the speed/duration remap menu the percentage and duration is grayed out. If only a few (less than 20 or so), then this solution works.
Tristan Finn
on Apr 18, 2019 at 1:55:38 am
man that is another feature I miss from Final Cut 7. Being able to search "Cross Dissolve" and have it highlight all of em and just hit delete.
Back when I was a AE, having to prep spots for finish it was a real pain to have to comb through to make sure I didn't miss any fades before sending out the picture prep.
I guess it's time to submit a feature request on adobe's site
https://www.adobe.com/products/wishform.html
Herb Sevush
Re: RemIt ove all cross dissolves
on Apr 18, 2019 at 12:31:12 pm
[Joseph Freeman III] "Is there a way to globally remove all instances of an effect, such as cross dissolve?"
Strangely enough there is a hardware solution:
https://palettegear.com/premiere-pro
Here's is a tutorial
If you order this with just a single "button" controller you can easily program this button to delete any/all transitions highlighted.
You would think that if an external controller can do this you should be able to do this with keystrokes, but you can't.
By the way, I have found that the other controller modules that Palette makes don't do anything you can't do by keyboard, so if interested just buy the single "button" controller.
Herb Sevush
Zebra Productions
nothin' attached to nothin'
"Deciding the spine is the process of editing" F. Bieberkopf
