New PC not performing correctly in Premiere Pro
James Morello
on Apr 9, 2019 at 4:09:33 am
Hi guys,
l've just put together a new pc specifically designed for 4k editing in Premiere and After Effects. However, it is not performing anywhere near as expected. It can't playback DJI P4P 4k footage without continually dropping frames. Is this normal? Seems to playback Sony A7 iii 4k footage ok but starts to struggle once colour grading and effects are added. The spacebar and playbutton will randomly stop working when switching to an internet browser then back into Premiere yet the marker button will still work. Once this happens Premiere cannot be closed normally, only via the task manager. I reset the preferences and it fixed the problem until it started happening again not long after.
Here is the list of pc parts below
Intel Core i9 9900K
Gigabyte GeForce RTX 2070 Gaming 8G OC Graphics Card
Gigabyte Z390 Aorus Ultra Motherboard
Corsair Vengeance RGB Pro 32GB DDR4
Seagate Barracuda 4TB
Samsung 970 EVO Plus NVMe SSD 1TB
Samsung 860 EVO 2.5in SATA SSD 1TB
l'm running the OS and any software on the Samsung 970 and then storing the projects scratch disks on the Samsung 860. Rendering wise it is performing very fast. l've ran stress tests on the CPU and there is no thermal throttling. Temps are around 60 degrees.
Tero Ahlfors
Re: New PC not performing correctly in Premiere Pro
on Apr 9, 2019 at 8:31:55 am
Transcode the footage to Prores or DNxHR.
Scott Thomas
on Apr 13, 2019 at 5:56:38 am
Maybe try to determine if there are different controllers for the different SATA ports. If the two SSD drives are on one bus, it may be getting saturated.
I took a look at the Gigabyte webpage and couldn't determine anything beyond that it had 6 SATA ports. I would guess there are at least two or three controllers. Some will be in the motherboard chipset and others will be on separate controllers.
I'm most likely wrong, but perhaps try moving one of the SSD drives to a different port.
