Correct project settings for 16mm scans?
Peter Humble
on Apr 9, 2019 at 12:39:17 am
I'm working with 16mm source scanned as a tiff image sequence for the first time and wondering how I should set up my project. A bit confused about the frame rate amoung other things.
Should my project frame rate be 24fps given film is 24fps?
But then if I'm finishing on video don't I need to encode it at 25fps? (PAL region)
By the way I'm working with an old CS6 version on a Mac.
If anyone could set me straight on this that would be great.
Chris Wright
Re: Correct project settings for 16mm scans?
on Apr 9, 2019 at 1:00:53 am
you'd have to determine what the native film frame-rate was, since you'll be choosing between odd looking speed changes or optical interpolation.
Peter Humble
on Apr 9, 2019 at 1:07:42 am
The film was all shot at 24fps
David Roth Weiss
on Apr 9, 2019 at 6:24:05 am
It was shot at 24fps, but was the image sequence shot 1 to 1 with any pull down, etc.?
It’s never as easy as you think, “most of the time.”
I’m going into a no cell zone, so y’all are on your own to sort out this mini-mystery.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Peter Humble
on Apr 10, 2019 at 1:31:36 am
Ok.....It was scanned 1 to 1....no pull down.
Chris Wright
on Apr 10, 2019 at 3:27:56 am
where's it going to? DVD? PAL can playback NTSC 23.976 stuff, web, doesn't matter.
