Having trouble exporting a project suddenly
Trevor Anderson
on Apr 5, 2019 at 6:22:06 pm
Hey everyone, long time reader, first time poster!
I'm having some trouble exporting a project on its second revision. It's not even that complicated, but I feel it's either because I just updated my video card with CUDA, or because I used a new set of presets. I'm currently working on Win10 x64, 12gb ram, Phenom II X6 1055T (2.8GHz), Premiere Pro CC 2019, Media Encoder 2019. Here's the report I'm getting;
- Source File: C:\Users\SUPERT~1\AppData\Local\Temp\NAR Promotional Video_2.prproj
- Output File: K:\NAR training\Output\NAR Training Video Rough Edit 2.mp4
- Preset Used: Custom
- Video: 4096x2160 (1.0), 23.976 fps, Progressive, Software Encoding, 00:01:33:10
- Audio: AAC, 320 kbps, 48 kHz, Stereo
- Bitrate: VBR, 1 pass, Target 10.00 Mbps, Max 12.00 Mbps
- Encoding Time: 00:12:53
04/04/2019 09:56:04 PM : Encoding Failed
The Operation was interrupted by user
- Encoding Time: 00:49:02
04/04/2019 10:45:37 PM : Encoding Failed
Export Error
Error compiling movie.
GPU Render Error
Unable to process frame.
Writing with exporter: H.264
Writing to file: \\?\K:\NAR training\Output\NAR Training Video Rough Edit 2.mp4
Writing file type: H264
Around timecode: 00:00:58:02 - 00:00:58:09
Rendering effect: AE.ADBE Geometry
Rendering at offset: 51.009 seconds
Component: EffectFilter of type GPUVideoFilter
Selector: 9
Error code: -1609629695
- Encoding Time: 00:52:10
04/05/2019 12:22:02 AM : Encoding Failed
Export Error
GPU Render Error
Selector: 9
Any help would be greatly appreciated!
Dan Sparks
Re: Having trouble exporting a project suddenly
on Apr 5, 2019 at 10:14:44 pm
I'm not on Windows so I don't know about those specifics, but did you look at the timeline at this point to see what is there? Is there a new video clip, or still image? Around timecode: 00:00:58:02 - 00:00:58:09
Dan Sparks
Tricom Video Inc.
http://www.tricomvideoinc.com
iMac Pro, 32 GB RAM 10 core, Radeon Pro Vega 56 8176 MB,
12TB LaCie 2big Dock Thunderbolt 3, G Raid 8TB
Trevor Anderson
on Apr 5, 2019 at 10:48:26 pm
Thanks for your reply. I have attempted moving the clip involved, but with the first rough, it didn't produce this result. The 'text zoom preset' was added, so I've attempted changing the effect, but i'm getting the same result.
Dan Sparks
on Apr 5, 2019 at 11:23:13 pm
Have you tried completely removing the clip for an export test?
Dan Sparks
Tricom Video Inc.
