Is there a way to make a list of EVERY linked file in a project?
Chris Dukes
on Apr 1, 2019 at 6:25:59 pm
Hi Everyone,
Basically, I want to use the list to audit linked files and make sure everything is collected into the main project folder. So, it would be great if the list includes the file paths as well.
Unfortunately, the Project Manager's Consolidate and Collect features are inappropriate for my workflow.
Chris
Tristan Finn
Re: Is there a way to make a list of EVERY linked file in a project?
on Apr 1, 2019 at 6:33:41 pm
Hmm the only way I can think of doing this is using the project manager on the sequence you are trying to audit. Maybe just copy it all into a folder once. Then every time you manage the project later you can try and copy the same files over and only the new media will be copied and you can sort by time added?
I know this isn't exactly what your asking for but this is what I did to help me keep track when sending a project back n forth between two people.
