Is it possible to update metadata in Premiere via xml import?
Robert Krueger
on Mar 24, 2019 at 3:36:46 pm
I would like to build a workflow where an xml import updates clip metadata in an existing project, e.g. adds new markers. Reimporting an xml does not do the job. I tried to set the "updatebehaviour" element to "replaceiffound", which per originla FCP 7 spec was meant for that purpose but that does not seem to change anything. Is this a dead end?
Thanks in advance for any input,
Robert
Trevor Asquerthian
Re: Is it possible to update metadata in Premiere via xml import?
on Mar 24, 2019 at 7:29:58 pm
Not sure if PP even imports ALE files but that’s how you merge new metadata with existing clips in Avid.
Maybe ask in the SDK forum in Adobe site?
