Does :01 mean one frame or one second?
John Stanowski
on Mar 22, 2019 at 9:01:16 pm
I have specs from WDAF which ask for a spot with slate and "there must be :01 black video before and after spot".
I called the station and had to leave a message. Thought I'd ask here while waiting.
2013 Intel MacPro
3.5 GHz 6-Core Intel Xeon E5
64 GB 1866 MHz DDR3 ECC
AMD FirePro D500 3072 MB
Software OS X 10.14.3
Adobe CC
Shane Ross
Re: Does :01 mean one frame or one second?
on Mar 22, 2019 at 11:51:08 pm
I would take that to mean one frame. 1:00 is one second. Hmmm...but thirty second spots are called :30 spots.
Yeah, this is a thing they need to tell you.
Shane
Little Frog Post
Dave LaRonde
on Mar 23, 2019 at 3:06:04 am
I call it one second.
They ought to be smart enough in Kansas City to know that a frame would be :00:01.
Dave LaRonde
Promotion Producer
Jon Doughtie
on Mar 24, 2019 at 10:54:14 am
One second makes more sense than one frame in this instance.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2017.1 (as of 8/2017)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
Bouke Vahl
on Mar 24, 2019 at 2:14:04 pm
[Jon Doughtie] " One second makes more sense than one frame in this instance."
Why?
One reason for having black before / after is to make butt-edits so there is black between the commercials.
No way you ever see two seconds of black between them, two frames makes totally sense.
I would guess it's a frame, but that is just a guess.
Bouke
http://www.videotoolshed.com
John Stanowski
on Mar 24, 2019 at 9:52:41 pm
Thing is what makes sense doesn't always matter. Like I said before, I get all kinds of specs from Stations. Some of them are very specific, some of them are so brief it almost seems like they're annoyed they have to tell you. And I don't always trust the people making/sending these specs. Over half of them seem to be more interested in teaching you how to use an FTP program to send them rather than making sure you prep the video correctly for them.
2013 Intel MacPro
Adobe CC
Todd Perchert
on Mar 25, 2019 at 2:46:26 pm
I'd say 1 second. Same as if I tell someone :30 or :15.
TC
Mark Suszko
on Apr 1, 2019 at 9:52:25 pm
Considering how sloppy some local cable companies can be, and the relative age of their play-out automation gear, my guess would be their play-out system needs one second of black "handles" front and back, to allow for dissolve transitions between other programming segments.
