Playhead returns to beginning when sequence tab is activated
Charlie Kosheff
on Mar 18, 2019 at 2:57:43 pm
When copying and pasting interview clips between sequences for a project (as in sorting clips into topic sequences)- the playhead always returns to the first frame of each sequence when I select the tab. This is annoying when you're trying to stick clips at the end of sequences to sort them.
Can I not work this way? Do I have to create subclips and stick them in topic bins instead>?
Charlie Kosheff
Re: Playhead returns to beginning when sequence tab is activated
on Mar 18, 2019 at 8:07:31 pm
Right so I have to click "end" every time. It's too bad because it's right at the end where I need it when I activate the sequence and then BAM it moves to the head for no reason by itself.
