Stripes / lines on footage
Fabricio Lima
on Mar 15, 2019 at 9:15:30 pm
I filmed a live concert with Sonys A7s II and I'm currently in the editing process. Some of the footage came with these stripes / line which I thought it would a frequency difference between the camera and the stage lighting, but I checked some tutorials online and nothing worked. I'm putting the link where you can see the footage, if somebody already faced this issue or have any solution for it, please, let me know.
LINK: https://www.dropbox.com/s/s0i6aui0tn52kek/ISSUE_MUSICVIDEO.mp4?dl=0
Shane Ross
Re: Stripes / lines on footage
on Mar 15, 2019 at 11:24:02 pm
Took me a while to see it, finally did in the white shirt.
That's a sensor issue. The footage is recorded that way, that's what's coming off the sensor. You need to tell the camera op right away what their camera is doing. Maybe have them test shoot in other locations.
Shane
Little Frog Post
Dave LaRonde
on Mar 16, 2019 at 3:52:49 am
I looked at your clip. If you can not re-shoot, you are stuck. You must use the footage as it is.
Dave LaRonde
Promotion Producer
Vince Becquiot
on Mar 16, 2019 at 8:43:03 pm
I think you're right, this looks like cheap LED lights/shutter issue, although it doesn't look like your typical roll.
The lower end LED lights dim by simply decreasing refresh rate.
Probably not something you can fix in post, although you can try playing with frame rates in the timeline.
I'm guessing this was shot at 60P?
Vince Becquiot
Indigo Live | Kaptis Media
San Francisco Bay Area
Fabricio Lima
on Mar 18, 2019 at 4:04:33 pm
It was shot on 24 p.
