Resize a sequence without changing the distance between the objects
michele cazzaniga
on Mar 15, 2019 at 7:15:56 pm
I created a sequence 1920x1080 with a lot of jpg elements (more than 100). Everyone of them has a simple movement with position keyframes. Now I need to enlarge the sequence to 4000x2250 (I need a wide zoom-out effect) but when i change the footage size all the objects maintain the original scale but they change their disposition into the sequence frame, positioning themselves to fill all the footage and changing the distances between each other. The same when I try to copy all the traces in a new sequence. Is there a way to enlarge the sequence without changing the position of the objects (keeping them in the portion of 1920x1080) without moving them manually one by one?
Thank you very much
michele cazzaniga
Re: Resize a sequence without changing the distance between the objects
on Mar 15, 2019 at 7:23:51 pm
I post two screens to clarify the problem:
