Pre-Rendered and previewed sequences for migrating to the new Premiere Pro CC 2019
Jake Robert Pasculado
on Mar 12, 2019 at 1:08:01 am
Hello and greetings!
I've just noticed that my previous save files from "Adobe Premiere Pro CC 2018" when opened/migrated to the newer "Premiere Pro CC 2019", never loads the pre-rendered sequences and I did observe that once migrated to the new version it auto locates the media and conforms the clips then it Indexes the pre-rendered videos, ex. (Inside the .PRV folder with file names "Rendered - 0a683271-4c7e-4ea4-85c3-cedccec010f1.mpeg").
Sadly, the results are it ends up with a yellow and red sequences instead of the green it's as if it was not pre-rendered.
Example before migrating:
Example result after migrating:
I also noticed that CC 2019 asks if do I want to rename the newly converted save file (2019), instead of replacing the older save.
Maybe I'm doing something wrong with my migration and/or workflow. Just to add some info some saves that I had was reused for newer projects. Your time and help is highly appreciated.
Thank you.
Best regards,
JRX
