Editting Webex videos
Craig Berman
on Mar 8, 2019 at 1:28:23 am
This has me stumped. I received a video that was done with webex and I brought it into Premiere to edit and it seemed to work fine, but when I export it, the video has sound but no picture.
Could it be I am having problems because it is only 6FPS? I tried to put it through media encoder to convert it to ProRes but I couldn't edit that video either.
Please, can anyone help me make sense of this?
Here is an image of the video info:
much appreciated,
Craig
Todd Perchert
Re: Editting Webex videos
on Mar 8, 2019 at 4:13:47 pm
I don't know how Webex records or anything. But what you could try is take that video into Handbrake and transcode it to constant frame rate. I'm wondering if it has a variable frame rate from Webex. It's possible you're video and audio may not sync if that's the case.
TC
Craig Berman
on Mar 8, 2019 at 5:26:29 pm
Thanks! I will give that a shot.
Ann Bens
on Mar 8, 2019 at 10:23:18 pm
I think minimum fps is 10.
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional
Craig Berman
on Mar 8, 2019 at 10:28:52 pm
No luck with handbrake. So strange
Kalleheikki Kannisto
on Mar 9, 2019 at 12:44:01 pm
Did you try converting it to an image sequence?
If nothing else works, you may have to resort to some nasty workaround like playing the video while screen recording it.
Senior Graphic Designer
Mark Suszko
on Mar 15, 2019 at 2:08:23 pm
That screen-capture ploy would be my last, desperate method, but before that, did you try running it thru FFWorks or FFmpeg?
