Exporting issues
Arthur Thondhlana
Exporting issues
on Feb 27, 2019 at 2:37:55 pm
Project shot at 1080p. I bring the project to premiere and sequence settings is 1440x1080, framing for 4:3 aspect ratio. I export with the same resolution settings and the final video is zoomed in. Any suggestions?
Shane Ross
Re: Exporting issues
on Feb 27, 2019 at 6:29:34 pm
WHy is it 1440? Is this HDV footage?
Shane
Little Frog Post
Arthur Thondhlana
on Mar 5, 2019 at 6:22:05 pm
The raw file is 1920x1080. My sequence settings is 1440 for the 4:3 frame.
Todd Perchert
on Feb 27, 2019 at 7:21:41 pm
You may need to clarify a bit more. You shot at 1440x1080 with like a Panasonic or something that does non-square pixels at a lower bit rate? Or you edited at 1440x1080 square pixels for a 4x3 aspect?
Then what are your export settings? And are you wanting to keep that 4x3 aspect?
So, some more details about your footage, sequence, export and final destination might help - where is this video destined to run?
TC
Arthur Thondhlana
on Mar 5, 2019 at 6:27:19 pm
No, I shot at 1920x1080. In premiere my sequence setting is 1440x1080. When I go to export, I export at 1440x1080. Upon viewing, it's zoomed in and I would like to keep the 4:3 framing I was watching as I was editing.
I'm sending the product to facebook
Shane Ross
on Mar 5, 2019 at 10:25:49 pm
SO, shot 1920x1080, wide screen. But edited 1440x1080 square, with those settings, and when you export 1440x1080, it's zoomed in? What are you export settings exactly?
Shane
Little Frog Post
