batch create sequences from a group of folders or text document contents
darren Coombes
on Feb 25, 2019 at 8:24:46 am
I have 175 clips and each of these clips has to go into it's own sequence. Therefore creating 175 different sequences.
My Issue is, each sequence needs to be a specific name, as its an exercise.
This way, each sequence then will be export as a seperate shot for compositing.
Is there a way to batch create sequences in premiere?
I have all the shots exported as folders, with the same names. Could I somehow use the folder names to create sequences? Or perhaps use a text document where each line of text is a sequence name?
Would save me a lot of time.
As future jobs could hold up to 500 + sequences.
Thanks.
Bouke Vahl
Re: batch create sequences from a group of folders or text document contents
on Feb 25, 2019 at 3:49:40 pm
I have no clue if it's possible in Premiere, but in Avid it's not a big deal.
If that is not an option, I could make you something that does this.
(Contact me directly if you would like me to make you an offer.)
Bouke
http://www.videotoolshed.com
