How do you add a preset to the In panel effect drop down lists?
James Barnette
on Feb 23, 2019 at 7:17:55 pm
I'm adding effects to the track mixer and I have a ton that I need to add the same setting to. I know how to make presets but,
How do I make a preset that appears in the preset dropdown for the effect?
for instance. I'm using "Parametric EQ" it has a dropdown at the top of the panel for the EQ setting. I have made presets but they don't appear in this list.
they show up under presets in the effects presets window but only there. Wich makes the useless if I can't apply them to the affect when it is in the audio track mixer.
John Pale
Re: How do you add a preset to the In panel effect drop down lists?
on Feb 24, 2019 at 5:02:50 pm
You can’t. Which is ridiculous and infuriating.
