Premiere pro UI blurry in 4k monitor.
Pedro Santos
on Feb 11, 2019 at 8:45:20 pm
Hello, guys!
My premiere pro UI is blurry (kind of out of focus) when using a 4k monitor.
I read somewhere that I should change the DPI settings in the properties.
When I do that, the UI does not look burry anymore. But, everything looks really small. Panels, letters, etc
Ill attach two screenshots for you guys to see.
The first two are with the DPI settings at default. The other one is changing the DPI to "app".
https://imgur.com/a/pspG5dw
https://imgur.com/a/pR8QiVv
https://imgur.com/a/z60iK83
Any help? Or this is the expected behavior?
Also, it happens with other adobe apps such as Audition and Illustrator. But, with Photoshop and Lightroom, I have no problem at all.
Thanks a lot already!
Todd Perchert
Re: Premiere pro UI blurry in 4k monitor.
on Feb 11, 2019 at 9:20:25 pm
Couple of things. You need to use native resolutions for that monitor, or you will get blurry images/text on that monitor. 4k on a pc monitor, at the highest resolution, will result in small text and icons. You should have additional sizes you can select that are still native resolutions, or you'll need to change your text size. Also, your video card needs to be able to do your resolution, or you can have blurry text - this includes the cables you use to attach to your monitor from the pc.
So, with that, what is your video card, PC, monitor, and how are you connecting it all?
TC
Pedro Santos
on Feb 11, 2019 at 9:31:57 pm
Hi! Thanks for the reply.
So, my pc is:
i7-7700K
LGA 1151 mATX PRIME B250M-PLUS
VGA ASUS Geforce GTX1060 6Gb GDDR5
4x HyperX FURY 8GB 2133Mhz DDR4 CL14
970 evo 512gb ssd
My display is a LU28E590DS.
The cable I am using came with the display and it is a displayport cable.
My windows zoom config is set to 150%, which is the recommended. My resolution is set to 3840x2160.
Todd Perchert
on Feb 12, 2019 at 4:15:33 pm
So you have the magnifier zoom level to 150%? When you change that from 100% to 150%, is that when the text goes a little blurry? Looking at your specs, everything should power that monitor just fine. But I'm wondering if your zoom setting is causing the issue. I would try finding a different resolution that works, rather than use magnifier zoom setting. Also, along with changing resolutions, try changing rate as well to see if you can find one that works with your setup.
TC
