select associated clips in timeline
Baba Luba
on Feb 11, 2019 at 7:52:47 pm
Hoi!
Is there a possibility to select a clip in the project window and then "say" select all clips used from this sourceclip in timeline?
like the opposite of "show in project window", when I right click a clip in timeline
a few versions ago it was possible, to set a labelcolor for a clip in the project window and then all the clips in timeline automatically changed into that color. Now this is not working anymore...
I need a possibility to select all clips used from an interview (actually i have many interviews)
I need to find a good way to NOT MISS a clip ;O)
i have a 60min documentary and I'm doing color correction now
thanks
Simon Ubsdell
Re: select associated clips in timeline
on Feb 13, 2019 at 9:17:10 pm
Every clip in the Browser has a sub-menu that shows you how many times and where it is used in a timeline.
Click on the downwards arrow to access this.
Then you can select any item in the list and Premiere will navigate to that instance on the timeline. It's a great feature.
Simon Ubsdell
hawaiki
