Laptop specs for premiere?
Dominic Reagan
on Jan 31, 2019 at 2:33:38 pm
Im planning on getting a dell xps 15 with the 6 core 8th gen i7, 16gb of ram, and a Gtx 1050 ti. Is this going to be fine in premiere? Also I've heard that it's not worth getting a 4k screen because your eye cant even conceive that its 4k unless the screen is 30" or more. Should I go for the 1080p or 4k screen?
greg janza
Re: Laptop specs for premiere?
on Jan 31, 2019 at 3:27:27 pm
I have the XPS15 9570 for portable work and it works very well.
A few recommendations, increase your RAM TO 32 gigs, swap out your wifi card and then underclock and repaste the CPU to counterbalance CPU throttling.
And yes, there's no need for a 4k laptop screen. Get the HD model and you can attach a 4k monitor through HDMI.
link to wifi card:
https://www.newegg.com/Product/Product.aspx?Item=9SIABG38GG5845
link to youtube tutorial to underclock and repaste:
Tallmanproductions.net | Windows 10 Pro | i7-5820k CPU | 64 gigs RAM | NvidiaGeForceGTX970 | Blackmagic Decklink 4k Mini Monitor |
Adobe CC 2019 13.0 | Renders/cache: Samsung SSD 950 Pro x2 in Raid 0 | Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280 x 2 | Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with Resilio
Dominic Reagan
on Jan 31, 2019 at 3:40:14 pm
If I got the model with 32 GB ram i would have to downgrade to the 7th gen core i7 which is quad core.
greg janza
on Jan 31, 2019 at 3:57:14 pm
Get the 6 core 8th gen i7 and then upgrade the RAM in the future.
Dominic Reagan
on Jan 31, 2019 at 4:02:41 pm
I'm not very good when it comes to customizing laptops so where would I have the ram/thermal pasting done?
greg janza
on Jan 31, 2019 at 4:35:18 pm
Any computer repair shop can do it but I'd recommend that you attempt it yourself. Use a video tutorial and a laptop tools kit. The process is very simple.
Dominic Reagan
on Jan 31, 2019 at 4:38:10 pm
And I can get the info for the type of ram I need online?
greg janza
on Jan 31, 2019 at 4:41:05 pm
RAM:
https://www.newegg.com/Product/Product.aspx?Item=N82E16820156182
tutorial:
Dominic Reagan
on Jan 31, 2019 at 5:40:14 pm
Thank you!
greg janza
on Jan 31, 2019 at 10:14:26 pm
Dominic Reagan
on Feb 1, 2019 at 12:34:02 am
One more question: I dont think the 1080 by 1920 screen has as high of a adobeRGB rating as the 4k screen. Should I be worried about this?
greg janza
on Feb 1, 2019 at 12:42:28 am
In a word, no.
If you have a color critical work flow then you need a real calibrated monitor. I wouldn't rely on a laptop monitor for any serious color work. And since the XPS15 has HDMI, you can easily connect a reference monitor to it for real color monitoring.
Dominic Reagan
on Feb 1, 2019 at 12:45:33 am
If I had to color grade a video for a client on the go, would I be able to get by with the color accuracy of the 1080p screen?
greg janza
on Feb 1, 2019 at 12:48:57 am
absolutely yes but I would recommend that you calibrate the laptop monitor with a real calibration tool like a spyder or x1 pro.
Dominic Reagan
on Feb 1, 2019 at 12:52:17 am
Thank you very much.
Dominic Reagan
on Feb 5, 2019 at 11:09:22 pm
New question. I have the option to get a 4k display version with the same specs as the 1080p version (except the screen) for the same price. What should I do?
greg janza
on Feb 6, 2019 at 2:26:30 pm
go for it.
Main Edit: Windows 10 Pro | i7-5820k CPU | 64 gigs RAM | NvidiaGeForceGTX970 | Blackmagic Decklink 4k Mini Monitor |
Adobe CC 2019 13.0.2 | Renders/cache: Samsung SSD 950 Pro x2 in Raid 0 | Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280 x 2 | Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with Resilio
Portable: Dell XPS15 9570
