Moving a clip without changing sequence duration
jo gali
on Jan 22, 2019 at 8:26:31 pm
Is there a way to move a clip left and right in without changing sequence duration? Say I want to move a clip in between a cut but I don't want to add time to my sequence. Would I be able to do this in one move via keyboard shortcuts? This move is similar to what you would do on AVID with the yellow arrows.
John Pale
Re: Moving a clip without changing sequence duration
on Jan 24, 2019 at 4:27:40 am
Use the slide tool
Jeff Pulera
on Jan 24, 2019 at 10:45:42 pm
I think if you just hold down the CTRL key first (on PC, don't know Mac) then you can drag the clip how you want. Make sure Snap is enabled (looks like magnet)
Jeff Pulera
Safe Harbor Computers
