Force audio waveform generation on chosen material in PP CC2018
Osku Petteri
on Jan 17, 2019 at 11:36:35 am
Hello fellas,
I've got a project which contains 5,1x2 + stereox2 audio tracks so i'm handling 16tracks of audio. The raw material per day is multiple hours long. So the audio waveform generation in premiere is out of the question, since it has to generate 16xhours of waveform. I would still like to have audio waveform in for certain selected clips, interviews SFX etc. What would you suggest on getting these waveforms visible? Basicly I would need a command that says 'generate audio waveform' on a certain raw clip, while all the other material would be just fine without waveforms.
Thanks for the help,
-O
Tero Ahlfors
Re: Force audio waveform generation on chosen material in PP CC2018
on Jan 17, 2019 at 12:41:38 pm
[Osku Petteri] "Basicly I would need a command that says 'generate audio waveform'"
Oh like the generate audio waveform command that's found under the clip menu.
Osku Petteri
on Jan 17, 2019 at 1:21:04 pm
Hahahahah,
Yes, just like that...BUT BETTER. I seriously did not find the answer with my google skills. I guess dem skills are pretty shitty. But there it is now, thanks!
