Title fade transition look like random ripples in a pond
Thano Karras
on Jan 7, 2019 at 11:24:39 pm
Dear friends,
I am trying to make a title transition somewhat similar with this
, but more fluidical like for example the ripples on the event horizon of stargate
Any help is greatly appreciated, many thanx
Kalleheikki Kannisto
Re: Title fade transition look like random ripples in a pond
on Jan 8, 2019 at 12:47:05 pm
That would be better achieved in After Effects. You can use a smooth fractal noise as a matte, animating the levels or threshold so it goes from black to white through a ripple-like effect. Then you could use the same noise for displacement mapping or use turbulent displacement to give it some water-like warping.
Senior Graphic Designer
Thano Karras
on Jan 8, 2019 at 2:07:25 pm
That worked! Thank you! :)
