Iris-in effect (not as a transition)
Eilat Ben-Eliyahu
on Jan 5, 2019 at 1:36:33 pm
Dear friends,
I'm excited! I've been using pieces of advice from this forum for years, and now is my first time to actually post a question.
I would like to create an "Iris In" effect on a logo.
So that most of the screen goes black but not all of it. I would then hold the Iris'd in image (logo) for a few seconds before the video fades to black.
I did a very simple sketch, using crop effect and keyframing it: http://f1.creativecow.net/12994/12994
However, it doesn't look as professional and awesome as I would like it to be.
What would you suggest?
Is it even possible to do in Premiere, or should I get my hands on After Effects?
Also, I'm not sure what transition I should use to switch between the video and the graphic. Morph cut didn't work well.
Eilat
Dave LaRonde
Re: Iris-in effect (not as a transition)
on Jan 5, 2019 at 6:06:16 pm
I think it would be a lot easier to do this in After Effects, where you can animate a circular mask and create a fade to black by animating the opacity on a black solid. Be prepared to learn some AE basics.
There are good tutorials on the Adobe web site made by the pros and not some high school kid.
Dave LaRonde
Promotion Producer
Eilat Ben-Eliyahu
on Jan 5, 2019 at 8:03:36 pm
Alright, thank you!
Ann Bens
on Jan 5, 2019 at 9:32:40 pm
Use the crop effect.
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional
Todd VanSlyck
on Jan 7, 2019 at 2:29:06 pm
Definitely After Effects, it's much easier to control. You could animate a mask however you like.
Maybe just a quick dissolve between the video and logo? Maybe you could run a subtle light sweep over the graphic right after the dissolve for extra flair.
Good luck!
TVS
Dell Precision 5810 Intel Xeon 3.0 GHz
NVIDIA Quadro M4000
Adobe Premiere Pro CC
After Effects CC
Cinema 4d r14
