Salutations creatives, so I'm trying to add renderings of a what a location will look like to stereoscopic VR footage of that same location the way it is today. However, well, an image is 2D and monoscopic. The closest I've come is using the "VR Plane To Sphere" effect, but it still doesn't line up properly on both halves, top and bottom. I have it lined up perfectly where I want it on the bottom (right eye) with the roof lines of the buildings, but it doesn't line up on the top half (left eye). If you'll notice in the attached screenshot, the top half rendering needs to be higher. More distance needs to be between the top and bottom renderings, but there's no control for that. Any ideas on how I can achieve this?
