PNG files won't show in exported material
costin becheanu
on Dec 23, 2018 at 11:18:01 pm
CC 2014
I have several stacked png files throughout my project. They are just black solids. In premiere they have multiple opacity masks.
Specifically when I check "use maximum render quality"... the final video will come out missing all the pngs.
If I export without it checked, everything exports fine.
Is this to be expected?
Ann Bens
Re: PNG files won't show in exported material
on Dec 26, 2018 at 7:17:20 pm
You dont need max render quality if you have a dedicated gpu card.
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional
costin becheanu
on Dec 27, 2018 at 10:31:27 am
Thanks. In the mean time I figured out how dumb I am. Max render was sort of cleaning up my work. What I did was I set my pngs opacity while having filmconvert on. Not being able to see in my previews nor in my non-max render exports the fact that the opacity work on its own for the pngs super low ... therefore I couldn’t see the pngs anymore. So I went back, turned filmconvert off, readjusted opacity for pngs, then turned on filmconvert ( saw very dark previews this time) but when exported with max render, it was fine.
Todd Perchert
on Dec 31, 2018 at 4:37:44 pm
Unless you are scaling to a different frame size, I'd just leave Max Quality Render off. I've gotten mixed results with it on even when scaling. So I never use it.
TC
