Premiere Pro - View video in different tracks on Timeline on separate program monitors?
Björn Johansen
on Dec 14, 2018 at 6:16:05 am
Hi all
I have two layers of video. One is on V1, the other on V2. Two cameras covering different parts/locations of the same event.
Is there a way to view the material simultaneously without having to make a multicamera sequence?
Warm regards
Björn
John Pale
Re: Premiere Pro - View video in different tracks on Timeline on separate program monitors?
on Dec 14, 2018 at 1:12:40 pm
No NLE does that. You need dedicated multi stream playback software for that job. Use the right tool for the job.
Mike Cohen
on Dec 14, 2018 at 6:06:58 pm
When editing two cameras, I make a PIP of both side by side, make my cuts, then clean it up. Multi-cam will do this too.
John Pale
on Dec 15, 2018 at 2:43:02 am
[Mike Cohen] "When editing two cameras, I make a PIP of both side by side, make my cuts, then clean it up. Multi-cam will do this too.
He's looking to output each camera on a different monitor simultaneously. Multicam or PIP will output both cameras on the same monitor. He needs two separate streams of video output.
