25p to 24p
Dean Daniels
25p to 24p
on Dec 10, 2018 at 11:17:15 am
Hi everyone, I am a bit of a novice so I would really appreciate some help.
I have some footage from the Canon c100 shot at PF25. I can't record with the 24p version because it's for 59.94hz only and I'm in the UK.
I want to achieve a 24p "film look", is it as simple as telling premiere to interperate it as 24p? It's a tricky one for me, because my audio will all lose sync if I do this, and I'm sure it's going to be a nasty workflow if I have to do this often.
Any help would be greatly appreciated
Thanks in advance
Dean
Dave LaRonde
Re: 25p to 24p
on Dec 10, 2018 at 4:54:14 pm
It's just one frame per second. Will you REALLY see the difference between frame rates?
I would simply shoot & edit at 25P.
Dave LaRonde
Promotion Producer
Shane Ross
Re: 25p to 24p
on Dec 10, 2018 at 6:22:50 pm
I agree...you'll get that film look shooting 25p...it'll look like 24p..
Shane
Little Frog Post
Tim Drage
Re: 25p to 24p
on Dec 17, 2018 at 1:47:32 pm
I agree with the other replies. 25fps is close enough to 24fps, will look more like a 'film look' than 'messed up jumpy skipping a frame every second look' or 'weird frame blending look' which you will get if you try to convert :)
Ann Bens
Re: 25p to 24p
on Dec 18, 2018 at 11:20:33 pm
Converting is going to be a big pita. Stick to 25p.
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional
Bouke Vahl
Re: 25p to 24p
on Dec 19, 2018 at 9:22:31 am
I totally agree with the others, BUT, if you have to go to 29.97, the trick is to slow down your 25P master to 23.976, then add NORMAL pulldown to go to 29.97i. (And do a pitch correction.)
This way no frames are lost, and the result is good (All movies on TV are shown in Europe speeded up, so they are shorter than in the theatre.)
Don't let the term 'advanced pulldown' fool you, that is easier to remove, but looks worse and is obsolete now.
Do note that your new master will be longer, so if you have a time restriction, do the math before you start.
Bouke
http://www.videotoolshed.com
