Question about doing a surround sound mix.
ryan elder
on Nov 27, 2018 at 12:55:04 am
In the surround sound mixing in Premiere Pro, it shows all the speakers and you have a dot, which you can move around, and the dot will get more quiet as you move it further back and more loud as you move it to the middle, etc.
However, is there a way to have the room reverb change, depending on the position of the dot? Like if the dot is further back in on the chart, is it possible to have the reverb grow higher therefore, and have it grow less as the dot gets closer to the middle, which of course is the actor getting closer to the camera?
