How to fix frame rate issue
latisha Willis
on Nov 22, 2018 at 10:45:08 am
I have a clip that is playing back as though it has been sped up. Is there a way to get it to play at normal speed?
Latisha
Frank Nauta
Re: How to fix frame rate issue
on Nov 23, 2018 at 6:59:08 pm
I suppose this video doesnt normally play at that speed? You can try to convert it to another codec or file format and import that into Premiere? I am curious to hear what the video does in other editors too.
latisha Willis
on Nov 23, 2018 at 9:55:06 pm
I don't really have another editor to try it with. What codec would you suggest?
Latisha
Frank Nauta
on Nov 23, 2018 at 10:00:04 pm
Depends on what codec it is now. You can try .h264 if its not already, else some mpeg codec might do. You could also slow it down in premiere if you dont want to use the audio, but it might look choppy
latisha Willis
on Nov 24, 2018 at 3:05:13 am
I did convert to H.264 using. Still same issue. :-(. I fear it may be a lost cause.
Latisha
