How do you export Proxy Files into a 4K movie?
Andrew Crittenden
on Nov 3, 2018 at 1:50:35 pm
Editing with premiere cc 2017.
Imported 4k footage as proxies. But now file is set up to change 4k into proxy files when imported. So I am working only with proxies.
Now I want to export into a fully rendered high res 4k file.
Is this possible?
If so, how?
Andy
David Baud
Re: How do you export Proxy Files into a 4K movie?
on Nov 3, 2018 at 7:49:32 pm
In Premiere CC 2018, if you have ingested proxy files associated with your original files, any time you export or render from your sequence, Premiere Pro will use the original file... so if you used the Premiere Pro feature you should be good to go... again in CC 2018... I don't know when this feature was introduced...
Otherwise, you could always manually reconnect your media to your original files and then do your export... just make your proxy files offline and reconnect with your original files...
David Baud
Colorist & Finishing Editor
KOSMOS PRODUCTIONS
Denver - Paris
http://www.kosmos-productions.com
Yair Bartal
on Nov 3, 2018 at 8:37:02 pm
"I don't know when this feature was introduced..."
That is so since the very beginning of the proxy procedure in cc 2015.3.
