Automate order clips on TL by timestamp, filename, start timecode
Andrew Luck
on Nov 2, 2018 at 10:47:14 am
Hello!
Do someone know way for Premiere Pro 2018 automate to put drone clips without audio on TL by timestamp, filename, start timecode (like in old FCP7). The most interesting point do it only with timestamp, because in other causes I foresee problems with rename plugins, scripts e.t.c.
Thank you, for help!
John Heiser
Re: Automate order clips on TL by timestamp, filename, start timecode
on Nov 6, 2018 at 3:05:05 pm
Can't you just sort the bin, multi-select the clips and drag them all to a timeline?
John Heiser
Senior Editor
o2 ideas
Birmingham
