Keyframe Issue
Chip Hess
Keyframe Issue
on Nov 1, 2018 at 2:49:39 pm
I am using PP CC 2015.3 to match the setup at work.
When animating stills last night, I encountered a mystifying
"drift". The stills would continue to move a bit past the end point
set in the panel. I tried deleting the keyframes and resetting,
to no avail.
Is there a setting somewhere I am missing...?
Jon Doughtie
Re: Keyframe Issue
on Nov 1, 2018 at 5:12:45 pm
First guess would be they had curves on them and need to be reset to linear.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2017.1 (as of 8/2017)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
Todd Perchert
Re: Keyframe Issue
on Nov 2, 2018 at 2:54:14 pm
You'll need to right-click your keyframe and set it to linear. It's probably set to bezier.
TC
