Reconnecting full resolution media sync problem!!!
Uri Valverde
on Oct 23, 2018 at 9:34:27 am
HI!
Just finished editing a video using proxies (batch created with Media Encoder).
Whenever I try to reconnect certain clips with their full resolution equivalent, a certain delay will appear, causing the full resolution video to shift about 1-2 seconds. I checked already and both the proxy and the full resolution clip have the same framerate, timecode, duration and audio tracks. Basically identical except for the resolution, of course.
This issue just happens in some clips, many others are perfectly in sync after reconnecting.
The only solution I found for the moment is to manually adjust all the delayed clips, but of course it's a pain in my lower end, since the video is quite long.
Anyone might know what is going on here?
Using Adobe Premiere Pro CC v. 12.0.0 (build 224)
Thanks in advance!!
